Farmall Tractors Discussion Board
Re: Need temp guage for 1949 Cub??????????
Posted by ltf in nc on September 06, 1999 at 06:24:29 from (206.228.213.10):
In Reply to: Need temp guage for 1949 Cub?????????? posted by Krazzy....Charlie on September 05, 1999 at 08:55:46:
To mount a temperature gauge where there is no engine block access hole I do the folowing. From a auto supply obtain a mechanical temperature gauge with a small bulb and a long capillary tube. Remove the radiator hose at the engine and place the bulb/capillary tube carefully into the hose with the bulb midstream of the coolant flow. If possible I tiewrap the capillary to the engine outlet below where the hose fits. Then I take a dab of silicon sealant and cover the capillary tube at the outlet neck and slide the radiator hose back in place and if you are uneasy about everything sealing with the tube sandwiched between the hose and the engine block outlet use two hose clamps staggering the clamp joints. Works fine and does not leak. On engines with two top and two bottom hoses this installation allows monitoring the temp on each side of the engine because you can install two separate gauges.
Post a Followup
: Re: Re: Need temp guage for 1949 Cub??????????
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
