Re: Voltage regulators failing
Posted by Bob M on February 15, 2003 at 05:32:28 from (66.66.123.133):
In Reply to: Voltage regulators failing posted by J.W. on February 15, 2003 at 00:06:06:
JW - Here's a few possibilities:
1 - Not using the correct regulator. (Gen and regulator must be matched w/ each other)
2 - Intermittant or poor ground at the regulator. Run a dedicated ground wire from the regulator base and ground it to the generator bracket.
3 - Ground polarity reversed. Some regulators are short lived when operated reverse polarity. These usually have polarity marked on them. (This is a long shot - most older regulators are polarity insensitive)
Any idea exactly WHAT is failing in the regulators - cutout contacts, relay coils, resistor burnout or ??? This could provide clues into the failure cause...
Post A Followup
: Re: Re: Voltage regulators failing
