Re: 706 with 310 German update
Posted by RO on February 15, 2003 at 16:12:21 from (24.124.48.58):
In Reply to: 706 with 310 German update posted by Desperate! on February 15, 2003 at 13:06:48:
Once again, I'm not sure the German Diesel uses the same injection pump as I have on my 560D w/282 engine. However,your symptoms are so similar to what I had.
On my injection pump, just above the cylindrical block where the injector lines are fitted with the banjo-type fittings, there is an adjustment screw with a jam-lock nut around it. Once you have the engine started and warmed up, put the throttle to the position where it begins to bog down. Then loosen the jamb nut and adjust the center screw in or out and see if it changes your engine performance. Premark the setting in case it doesn't impact the performance.
Post A Followup
: Re: Re: 706 with 310 German update
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
