706 with 310 German update
Posted by Desperate! on February 15, 2003 at 13:06:48 from (209.51.206.198):
I removed return line going to bottom of fuel tank thereby bypassing check valve.ran a piece of hose from return line to gallon jug. Had good flow.didn't seem to help the problem.logic would suggest that it is one of two problems. 1- fuel 2-timing.Since I have pretty much gone through the entire fuel system and still have the same results, I thought I would check valve timing. According to the book one tooth off is equal to 11 degrees of timing.
Post A Followup
: Re: 706 with 310 German update
