Re: 706 with 310 German update
Posted by the tractor vet on February 16, 2003 at 07:53:48 from (216.196.13.245):
In Reply to: 706 with 310 German update posted by Desperate! on February 15, 2003 at 13:06:48:
I am in the dark on this as i have come in on the tail end , how about and update as to the problem . I you are having hard startin problems with it and it does not help when you pull it into COLD start posision then you are having low pressure at cranking speed and that will require a injection pump rebuild to solve the problem . And with that pump it is getting to be a problem as the parts are getting hard to find and are BIG BUCKS . Also to find a GOOD shop that can do that pump wright is getting harder to find . Ya have to find a shop that has a OLD FART that knowes them inside and out.
Post A Followup
: Re: Re: 706 with 310 German update
