Re: Leak in front crank oil seal....
Posted by Roger on February 16, 2003 at 18:59:36 from (198.31.223.73):
In Reply to: Leak in front crank oil seal.... posted by Doug in NJ on February 16, 2003 at 16:33:01:
Doug, What did you do when you did the engine job? You must not have replaced the front seal. You are correct in that you basically have to remove everything on the front of the engine. You can replace the seal without taking off the timing gear cover, by prying out the seal, but it is better to remove the timing gear cover. Just below this posting (C113 engine Seal) there is another horror story about the difficulties removing the crankshaft pulley. You need a good puller and either a bearing separator or make something such that you do not pull on the cast iron pulley edges as that will certainly break it as the person below did. I bought a cheap set of bearing separators from Harbor Freight several years ago as the US name brand ones are so expensive. The Chinese ones from Harbor Freight seem to work OK for the times I have used and abused them. Getting the crankshaft pulley back on is another story as you need to get it on without damaging the crankshaft. I heated the pulley up (not too hot as you don't want to damage the new seal) and then drove it on with a big hammer and block of wood. Some crankshafts have a threaded hole in the center, and if so you are in better shape as you can pull it on. Good luck. Roger
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
