Re: SMTA Clutch Shaft
Posted by Wardner on February 17, 2003 at 05:04:26 from (65.235.132.145):
In Reply to: SMTA Clutch Shaft posted by Dave in MN on February 16, 2003 at 21:05:42:
Like they say, "a picture is worth a thousand words". You NEED some pictures. Do yourself a favor and get a parts books at the very least. A service manual would also be helpful for no other reason than it would give you torque values and tolerances.
Your description above is confusing. The seasonal disconnect is nowhere near the clutch. It is at the countershaft level whereas the input power for the LPTO and TA are at the mainshaft level. Power for the tranny is splined into the main clutch disc. Power for the LPTO is splined into the pressure plate. The IPTO shaft, which is hollow, carries a gear that meshes with a gear below it. That lower gear and shaft is where the disconnect is located. BTW, that gear, shaft, and bearing need close inspection for wear.
Post A Followup
: Re: Re: SMTA Clutch Shaft
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
