Re: what should you check for and do on a engine overhaul on a cub
Posted by wvhogleg on February 19, 2003 at 05:12:33 from (208.169.106.229):
In Reply to: what should you check for and do on a engine overhaul on a cub posted by rob on February 18, 2003 at 21:12:31:
my old cub had the same thing happen. i started using, and taking care of, the cub after my dad died. when i went to change to oil in her, the pan oil was jet black, and the filter housing drain would not drain. i got a long screwdriver and put it up in the tube to pull out all that congealed oil, which was the consistancy of grease. i had to give it a good cleaning. the old non-detergent oil had been used for many years which, from what ppl tell me, is what caused that. i used detergent oil in it now, and just keep changing the filter very often.
Post A Followup
: Re: Re: what should you check for and do on a engine overhaul on a cub
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
