Re: Re: Re: Re: Re: Re: Super WD9 Gas Starting Problems - HELP NEEDED PLEASE
Posted by Clark on February 19, 2003 at 05:51:58 from (64.140.62.4):
In Reply to: Re: Re: Re: Re: Re: Super WD9 Gas Starting Problems - HELP NEEDED PLEASE posted by Bob M on February 18, 2003 at 19:52:07:
Bob,
Thanks again. Yes, I do have a steady stream of gas coming out of the carb bowl drain plug and it quits once I put the transfer lever back into diesel. I do have another question if you don't mind. My neighbor happened to have an old IH MD manual that I was reading last night. They refer to a "snap" that should occur when you move the transfer lever. Well, mine does not "snap", in fact it's quite smooth. It doesn't want to stay in the gas position without holding it there manually. But there certainly isn't a "snap". This "snap" they are referring to, is that something that goes overcenter? I don't see anything in the linkage that should "snap" on either side of the engine but maybe there's something I'm missing or did I must misinterpret the manual? One other thing, the motor seems to turn over at the same speed whether the starting valves are open or closed (lever in gas or diesel). I would have thought the motor would have turned over easier (faster) when the lever is in gas which is supposed to reduce compression from approx. 15:1 to 5:1. Once again, thank you very much for your time and thoughts, I appreciate it.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Super WD9 Gas Starting Problems - HELP NEEDED PLEASE
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
