Re: H in line fuel filter
Posted by Pappy on February 20, 2003 at 21:07:22 from (205.188.209.78):
In Reply to: H in line fuel filter posted by john on February 20, 2003 at 17:45:48:
If you are using the silver colored filter with the two rubber hoses and four spring clamps, (that's what I use) be sure you can blow through the filter before installing it. Some of the filters were made for gravity flow, and some are to be used with a fuel pump. I use the cheaper ones. I tried a more expensive filter, (WIX) and it will not work at all.
Post A Followup
: Re: Re: H in line fuel filter
