Re: Re: Re: Farmall A engine ID, electrics
Posted by Bob M on February 25, 2003 at 07:06:39 from (165.170.128.68):
In Reply to: Re: Re: Farmall A engine ID, electrics posted by Ted on February 25, 2003 at 02:11:27:
Ted - If you've got experience wiring machine tools, you'll find rewiring a Farmall is a snap!!
You've described a 4-position light switch (consistant with 1947 model year). Your tractor was orginally supplied with a generator cutout (thus the 4 position switch) but someone later swapped it for a voltage regulator. The regulator not original, but makes for improved electrical system performance. Punch below for a diagram that shows how the system should be wired up.
Also your light switch has gotta be wired incorrectly. Lights should work like this: All lights off in the first two switch positions (L and H positions). Front lights dim and the rear bright in the 3rd position (D). All 3 lights should burn bright in the last (H) position.
Hope this helps! If you have more questions email me back offline. ...Bob M
Post A Followup
: Re: Re: Re: Re: Farmall A engine ID, electrics
