Re: Propane fuel, can you put gas in the tank and drive off?
Posted by NDS on February 25, 2003 at 14:51:49 from (152.163.189.203):
In Reply to: Propane fuel, can you put gas in the tank and drive off? posted by Farmall Daddy on February 25, 2003 at 14:34:41:
It is not that simple at minimum carberator and fuel lines will have to be changed. Most LP tanks do not have bottom outlet and don"t think you would want to use them for gasoline if they did. Have owned trucks that would run on LP or gasoline but they essentially had 2 seperate fuel systems with lp carberator mounted on top of gasoline carberator.
Post A Followup
: Re: Re: Propane fuel, can you put gas in the tank and drive off?
