3 timing notches on crank pulley which one to use???????
Posted by Chad Penny on February 26, 2003 at 08:23:38 from (152.72.252.244):
Putting this farmall H back together and I want to adjust the valves and I need to install the distributor yikes!!!!!
Which notch on the crank pulley is the correct one to use? There is 1 by itself and then there is two other ones about 3/8" apart and half way around the pulley from the other. I thought the singal one was the top dead center mark but I looked in the spark plug hole and I could not see the piston so I rolled it around till I seen the piston and both valves were closed. It is close to the two marks. Which one of the two marks do I use? Please help
Chad
Post A Followup
: Re: 3 timing notches on crank pulley which one to use???????
