Farmall W-4
Posted by Phil on February 26, 2003 at 18:02:50 from (69.3.110.60):
What is the value of a Farmall W-4 with a serial number starting with an S (means Super H, I think)and is below 1000. As I understand the serial numbering system it started at 500, so this is low. Tin work is in good shape, and the unit is supposed to be runable and in good condition. Fenders are a litte rough, but look very fixable. Tires are okay. Appears the steering rod from the rear to the front axle has been welded at the rear and there appears to be a substantial amount of play in the connection at the front alxe. (I am not just sure what to call this item, but I hope this explains the situation clear enough.) All the rest of the unit is there. Thanks.
Phil
Post A Followup
: Re: Farmall W-4
