Re: Would a two-bottom plow for a 'C'
Posted by Bill Smith on February 26, 2003 at 21:13:25 from (128.242.4.59):
In Reply to: Would a two-bottom plow for a 'C' posted by Gary The Rookie Farmer on February 26, 2003 at 17:35:26:
You are correct. The H is Farmalls next size bigger tractor. I read CNKS's post and your follow up questions. CNKS is right. Mounted equipment is just what it sounds like. Equipment that is mounted on to the tractor itself. What CNKS meant by pull be-hind equipment is equipment that you simply back up to and pin it to the draw bar. An example of that would be a 4 wheel wagon. An example of mounted equipment would be like your belly mowers, or belly mounted cultivators. This type of equipment more less has to be bolted to tractor. Since the H is somewhat different in size and so forth, your mounted equipment for the C is probably not going to fit on the H. But anything that is "draw bar pin hook up" on the C will work just fine on the H.
Post A Followup
: Re: Re: Would a two-bottom plow for a 'C'
