Re: M Piston Pin Bushing
Posted by Bill Hires on February 27, 2003 at 09:40:31 from (128.206.231.133):
In Reply to: M Piston Pin Bushing posted by Mr. J on February 27, 2003 at 08:13:33:
Take it to a machine shop and have it honed to the correct fit, this is a floating pin. With oil on the bushing, piston and pin you should be able to push it in with your thumb(s). You can put the pin in a freezer, or use dry ice on it to shrink it, but you shouldn't have to do this. The piston pin diameter is 1.3125-1.3128, piston pin clearance in piston should be 0.0001-0.0003, piston pin clearance in rod bushing should be 0.0005-0.0007
Post A Followup
: Re: Re: M Piston Pin Bushing
