Re: Re: Farmall 140 clutch
Posted by John Sanders on February 27, 2003 at 18:59:56 from (65.82.110.245):
In Reply to: Re: Farmall 140 clutch posted by Gary on February 26, 2003 at 11:54:46:
Thanks Gary for the information, I think I probably do need to replace the clutch presure plate and throughout bearing,but what had happened was the clutch was stuck, and I had to break the tractor to free it, I adjusted the fingers down before I let the tension off of the pressure plate and I was looking for the correct height of the fingers, but I guessed at it and put it back.It has a little chatter,not bad though.
Post A Followup
: Re: Re: Re: Farmall 140 clutch
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
