Farmall Tractors Discussion Board
Re: won,t shift out of gear
Posted by JK MN on September 08, 1999 at 08:28:35 from (207.242.199.131):
In Reply to: won,t shift out of gear posted by larry on September 08, 1999 at 08:14:55:
larry,
If it has the TA, pull the lever to the back position and try shifting. If it still dosen't shift easily, re-check the clutch and TA adjustments. If linkage and adjustments are correct, the TA will be in low when the clutch pedal is pressed all the way down.
Post a Followup
: Re: Re: won,t shift out of gear
