Farmall Tractors Discussion Board
won,t shift out of gear
Posted by larry on September 08, 1999 at 08:14:55 from (147.253.19.27):
I was using my 300 utility last night to move
some stuff around the yard when i was in first
gear i could not get it to shift in reverse to
save my life,the only way i could do it was to
shut tractor OFF then it would shift to neutral
then i started it up again,what could be the
problem new clutch,pressureplate,thro out bearing
and all the other gears shift smoothly from first
thru fifth with no problem.please help,thanks
Post a Followup
: Re: won,t shift out of gear
