Farmall Tractors Discussion Board
Re: won,t shift out of gear
Posted by Farm-Al on September 08, 1999 at 11:13:23 from (205.188.198.182):
In Reply to: won,t shift out of gear posted by larry on September 08, 1999 at 08:14:55:
The TA adjustment on these tractors is the main cause of hard shifting. Be sure the linkage is not excessively worn at the pins. when you depress the clutch petal it must also release the TA clutch, you must also be sure when the TA lever is ahead you have a small amount of free play at the TA release bearing. GOOD LUCK Larry
Post a Followup
: Re: Re: won,t shift out of gear
