B414 BRAKES
Posted by BOB on March 02, 2003 at 16:44:08 from (142.176.115.174):
I've had the drums and discs of my 414 and found lots of oil which I assume is leaking from the splined shaft which holds the brake assembly.There is a ring containing 6 bolts which would have to be removed to replace the seals which I again assume are behind it.What needs to be done to remove them, gear puller? Am I on the right track?
Post A Followup
: Re: B414 BRAKES
