Re: 400 smokes black and fouls plugs
Posted by Wayne Swenson on March 02, 2003 at 20:03:20 from (66.228.233.124):
In Reply to: 400 smokes black and fouls plugs posted by John Humphrey Morocco IN. on March 02, 2003 at 17:59:24:
Remove the air cleaner hose at the carb and run the engine to determine if there is a intake restriction.
Is the camshaft correctly timed to the crank? Hard to determine without removing the front cover.
Set the timing so it fires at TDC (double notch--engine not running) and check for advanced timing (single notch--engine at fast idle) with your timing light.
Is the engine using oil and fouling plugs that way?? Wet black fouling = oil consumption. Dry sooty fouling = excess fuel.
Post A Followup
: Re: Re: 400 smokes black and fouls plugs
