Re: Re: rad hose and clamp geting hit by water pump fan blades
Posted by farmall man on March 05, 2003 at 10:22:10 from (209.103.199.92):
In Reply to: Re: rad hose and clamp geting hit by water pump fan blades posted by Bill Smith on March 05, 2003 at 10:10:53:
it is off another H. i had the problem with the other rad. the other one has had the over flow tube riped off by the fan. when i redone the motor i took a look at the old rad and seen that the bolts on the bottom seemed to have snaped off. it is only two of the blades that hit the tube or clamp. i do now that i need to rebiuld the pump, the bearings are wearing out and it wobbles a little . but i dont think this is it.
Post A Followup
: Re: Re: Re: rad hose and clamp geting hit by water pump fan blades
