Re: How do U fix Farmall 140 loose steering.
Posted by Haas on March 06, 2003 at 06:01:01 from (166.72.245.82):
In Reply to: How do U fix Farmall 140 loose steering. posted by 140 owner. on March 06, 2003 at 04:38:20:
You will need to replace all the seals and check the bearings and bushings to make sure they are tight. An easy check is to drain the oil out of the box and then remove the big plug with the hex on it from the front of the box. You can then turn the steering wheel while holding the wheels straight and screw out the worm gear enough to check the ball thrust bearing on the end. If it has any play replace it. This bearing is cheap, about $10. The big plug is the clamp that holds the bearing outer race in place, so the plug must be tight against the race. You may have to put in a washer to get it to tighten up, but make sure the washer contacts only the outer race and the plug and none of the other bearing parts. Also, the castle nut that holds the bearing on the worm shaft must be tight so that the bearing race can't move on the shaft. The bearing that hold the worm wheel and shaft may need to be replace too, but you have to take a lot more apart to get to them. It is very expensive to replace the worm gear and the worm wheel gear. The worm gear and the steering wheel shaft are all one piece. You should be able to get acceptable results by replacing bearings, bushings and seals.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
