Re: Re: My M is sick
Posted by Scott Price on March 09, 2003 at 08:43:01 from (64.22.197.78):
In Reply to: Re: My M is sick posted by Ty on March 09, 2003 at 07:01:57:
You say ran good until new manifold. I think that the other post may correct about checking the manifold gasket. Sounds like you have uneven air/fuel mixtures between the inner and outer cylinders. It runs good for a few minutes, until it fouls the middle two. You had also said earlier that the plugs in 1 and 4 look almost too clean, which could indicate that those two are too lean, while the middle two are too rich. I would also carefully inspect the manifold for defects. If you bought a new manifold, it could have a casting flaw that is either causing the gasket to not seal, or creating some restriction. The other thing I would wonder about is the electronic ignition. I know you checked spark, and switched plugs and wires around to check, but you could have a heat related problem in ignition that causes a weak spark to the center two cylinders after engine gets warm. If the engine was not warmed up enough when you did the ignition tests, the problem may not have been evident. Did you install the electronic ignition at the same time as the new manifold? Sounds like you have it narrowed down to a fuel fouling issue. This points to either weak spark on those two cylinders, or incorrect air/fuel mixture in those two cylinders. Either one could cause the engine to seem to run OK when it is cold, and then start to foul as it gets hotter. Keep us posted. We all seem to love the challenge of troubleshooting some of these pesky problems.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
