Re: Re: Re: Re: Super A hydraulic pump
Posted by CNKS on March 11, 2003 at 18:28:25 from (207.178.96.211):
In Reply to: Re: Re: Re: Super A hydraulic pump posted by Al on March 11, 2003 at 06:08:28:
Used a speedi sleeve on mine, but the hole the shaft goes thru had to be drilled out so it could turn.
Post A Followup
: Re: Re: Re: Re: Re: Super A hydraulic pump
