Re: Re: Re: Super A hydraulic pump
Posted by Al on March 11, 2003 at 06:08:28 from (65.161.226.217):
In Reply to: Re: Re: Super A hydraulic pump posted by Hugh MacKay on March 11, 2003 at 03:05:39:
The main problem these pumps have is the shaft seals get bad and you lose hyd. oil into the crankcase. If this happens change your oil and fix the pump as it'll dilute the oil and cause BAD problems! I have heard tell of people replacing the seals and I've heard of people just replacing the pump. Last time I priced a new one at caseIH it was over $250 and that was several years back. The problem with replacing the seals is the shaft is usually grooved where the old seal was. It looks like a speedi-sleeve could fix the pump shaft but never tried it.
HTH
Al
Post A Followup
: Re: Re: Re: Re: Super A hydraulic pump
