Re: IH 560 Hyd. problem
Posted by RPM on March 14, 2003 at 07:34:23 from (209.152.115.185):
In Reply to: IH 560 Hyd. problem posted by butch1cow on March 13, 2003 at 20:08:04:
I wonder if the tractor has power steering, it was a option, do you have 2 small lines going up to the front bolster, otherwise if it does you must have 2 pumps, one is mounted onto the other main pump in the clutch housing, called a tandem pump, the smaller pump is for the ps, has its own circuit and relief, its drive and oil supply is common with the other.
Post A Followup
: Re: Re: IH 560 Hyd. problem
