Farmall Tractors Discussion Board
Re: over-running coupler
Posted by Ludwig on September 09, 1999 at 11:57:15 from (208.201.105.254):
In Reply to: over-running coupler posted by paul on September 09, 1999 at 09:53:55:
The trick for mowing with out the O/R clutch is, as you probably know, to plan ahead. I've mowed plenty with a Super M and 6ft mower, you can't stop on a dime, but if the brakes are good and you haul yourself up on the pedals it's okay. I can get stopped from second gear in about 30ft. less if it's uphill or in real heavy conditions.
Post a Followup
: Re: Re: over-running coupler
