Farmall Tractors Discussion Board
Re: over-running coupler
Posted by ltf in nc on September 09, 1999 at 13:34:36 from (206.228.213.213):
In Reply to: over-running coupler posted by paul on September 09, 1999 at 09:53:55:
I assume that your drawbar must be straight as opposed to a vertical offset type. The offset version can just be turned over. I would make a device like a receiver hitch for a truck and mount it on the drawbar. Then I would make an insert of the height I desired. It is convenient also to make an adapter to mount a ball to the "receiver" hitch. I even have one for a pintle hook. This will let you move a trailer, etc. around without have to bolt everything together. Should you decide to get an overrunning clutch, I bought one that readily attaches and dismounts very reasonably, $41.90 delivered from 1-800 345 -0169. The 1 3/8" x1 3/8" diameter ones are $2 more. An overrunning clutch is a must on these older tractors to avoid stressing the drive line as well as it is much safer.
Post a Followup
: Re: Re: over-running coupler
