Re: 1st timer for 140 pressure plate removal
Posted by LanceM on March 15, 2003 at 16:33:15 from (216.241.144.130):
In Reply to: 1st timer for 140 pressure plate removal posted by Mitch in NC on March 15, 2003 at 15:34:31:
You're fine, the pressure plate is a unit. The mounting bolts just mount it to the flywheel and don't compress the plate springs. You will need an alignment tool when you put it back together as the pressure plate is the only thing holding the clutch disk right now, when you pull off the pressure plate the clutch disk will fall out.
Post A Followup
: Re: Re: 1st timer for 140 pressure plate removal
