1st timer for 140 pressure plate removal
Posted by Mitch in NC on March 15, 2003 at 15:34:31 from (209.215.27.116):
I'm currently replacing a cracked block with another running engine that has a clutch already on it. Wanted to examine the plate, bearing, and flywheel, but when I tried to remove pressure plate screws, I noticed springs behind plate were under tension. Is this normal? Will I be able to restart those short screws without somehow taking pressure off fingers? Never been in a clutch before...DUH.
Post A Followup
: Re: 1st timer for 140 pressure plate removal
