Re: What kind of oil goes in a belly pump for a Farmall H
Posted by Steven@nd on March 16, 2003 at 07:31:08 from (12.15.56.163):
In Reply to: What kind of oil goes in a belly pump for a Farmall H posted by 44H on March 16, 2003 at 05:46:20:
Do not use 30w oil in your belly pump. There is a big difference between 30w and straight 30 weight non-detergent oil.
30w is a winter oil (hence the w). 30 weight non-detergent is necessary because regular detergent motor oil (common oils on the shelf) will foam in a hydraulic situation.
I use Hy-Tran or universal hydraulic fluid in my belly pump and I haven't found anything I can't lift yet.
Post A Followup
: Re: Re: What kind of oil goes in a belly pump for a Farmall H
