Re: piston/sleeve size
Posted by John In Iowa on March 16, 2003 at 09:22:53 from (199.108.164.40):
In Reply to: piston/sleeve size posted by Dave on March 15, 2003 at 21:40:17:
The M had a C–248, which when they came out they, had 3 7/8” piston in them. You could install a 4” piston in that engine. The Super M and the early 400’s had a C–264 engine that came out with a 4” piston and 1 1/8” wrist pin. Both these engine came out with steel pistons. The later 400’s had a 1” wrist pin in a C–264 engines with a 4” aluminum piston. The 450’s came out with a 4 1/8 aluminum piston in a C-281 engine. With the sleeves removed from the C-264 and the C-281 engines the bore in the block was the same and actually both blocks(C-264 and C-281) have the same part #. The C-248 engine had a 1/8” smaller bore.
John In Iowa
Post A Followup
: Re: Re: piston/sleeve size
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
