Re: How to tell if charging
Posted by Ludwig on March 18, 2003 at 06:59:13 from (141.154.116.144):
In Reply to: How to tell if charging posted by Sean in Calgary on March 17, 2003 at 15:18:49:
Also remember that running for short periods will run your battery down. The generator is sized so that it'll charge the battery over time, but not in 10mins. As to water, in the winter this will always be a problem, the gas tank is vented so in the daytime it warms up and the gas and air expand a bit. At night as it cools it draws in air, and moisture. If I had to store outside I would always make sure to throw a tarp at least over the gas tank to keep the vent covered so if it rained or snowed it would keep that out. If you've got enough water in the system to freeze hard enough that it won't start you need to pull the gas tank and drain and flush it thouroughly. I'd drain and then fill with boiling water and flush and drain again. This would be a good time to seal the tank too while you have it off. Remember to get it really clean before sealing. Then drain the carb too. The carb is the lowest point in the system, water is heavier than gas and so should settle to the lowest point. Another thing to help with cold starts in the winter is a magnetic block heater. I'd stick it on the oil pan 20mins before I went out to start in the morning. Warm oil will flow so much easier it would make a big difference. I'd also consider 5w30 oil or maybe 10w30 synthetic. My truck starts far better when its cold with the synthetic in it. You could use the lighter oil only in winter, switch back to a heavier weight in the summer. Maybe you could even save the synthetic for next winter? Probably not the best idea, but that stuff is expensive.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
