Farmall Tractors Discussion Board
Re: H tank removal
Posted by The Red on September 10, 1999 at 07:18:50 from (206.246.187.2):
In Reply to: H tank removal posted by Fred on September 10, 1999 at 05:29:00:
Fred I have found the easiest way to separate them is to take the big ol nut off the upper bolster, remove pin and bearing and screw the front steering shaft out. It should pull right off the U joint. That U joint probably has a washer in the slot as opposed to the original half key.
Post a Followup
: Re: Re: H tank removal
