Re: 300U Steering Shaft Seals -- Need Help
Posted by Les Repair on March 20, 2003 at 18:24:21 from (67.0.87.84):
In Reply to: 300U Steering Shaft Seals -- Need Help posted by Kilian on March 19, 2003 at 18:20:16:
If I understand correctly, you are referring to the shafts with the steering arms are attached. If the seals on the power steering valve which on the steering column leak hydraulioc oil into the steering gear box it will cause the seals you are referring to to leak also.
Post A Followup
: Re: Re: 300U Steering Shaft Seals -- Need Help
