Re: Battery Chargers
Posted by Bob M on March 21, 2003 at 06:22:46 from (165.170.128.68):
In Reply to: Battery Chargers posted by Hugh MacKay on March 21, 2003 at 05:40:48:
Hugh - Sounds like you got yourself a "cosmetically challenged" but fully functional unit! The voltage readings vs dial settings sound about right for a working battery charger. Here's how it might be utilized: 1 - "Low" settings (both 6 and 12 volts): Use to slow charge batteries. If you're not in a hurry this is the best way to bring up a down battery without putting undo stress on it. You'd typically let the battery charge for 12 - 24 hours on this setting 2 - "High" setting (both 6 and 12): Use to bring up a dead battery in an hour or two. Actual duration depends on initial state of charge, battery capacity and charger amperage on the high setting. You'd use the timer with this setting so you don't overcharge/damage the battery. 3 - The "medium" 12 volt setting I suppose splits the difference between #1 and #2. Not sure what it's actually useful for…. 4 - "Boost" setting is to provide an extra kick to help a partially discharged battery start a vehicle. To use you set the charger to boost and let it charge the battery for a minute or two. Then crank the engine with the charger still connected and boosting. Note that boost is a limited duration function for the charger. The charger will eventually overheat and (should) cut itself off if the boost lasts more than a couple of minutes. Boost is also hardest on the battery. The polarity light will come on if you've got the charger hooked to the battery backward and the battery is not completely flat. Have fun, and don't forget that new knob for Mrs McKay's oven!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
