Re: H transmission seals
Posted by Tim K. on March 22, 2003 at 00:28:43 from (216.175.23.46):
In Reply to: H transmission seals posted by Dan G on March 20, 2003 at 10:41:32:
Dan , When you put your new seals in , place them just flush with the front of their retainers and they will be perfect. That top seal can be installed with a short cut. Loosen the four bolts that hold coupler to the clutch shaft and transmission drive and remove them. Now reach up and remove clutch return spring, now remove throwout bearing carrier bolts and slide out shaft and remove thick washers on shaft. Then remove the bolts that hold the pot metal piece to the tractor clutch housing. Now remove pressure plate bolts one at a time and re-install three of them back in holes provided in pressure plate to hold it together for easy reinstallation. The whole assembly will come out together , clutch shaft and all out the bottom and saves splitting the tractor. When going back together just line everything up and stick it up in the hole and push the clutch shaft into the pilot bearing and it should stay while you put your pressure plate bolts back in. Make sure you swing your throwout carrier up into position before you set it in place.. The reason I tell you this is because that main shaft drive coupler won't come off unless the clutch shaft is out of the way. Don't try to push it out of the way because you risk busting the ears off the pot metal throw out carrier. Good Luck Tim K. ps. The 4 bolts that hold the clutch shaft to the coupler can be very stubborn so loosen them then pry with a crow bar against the seal retainer bolt heads and they should give a distinct pop and come loose...
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
