Re: Re: H transmission seals
Posted by Dan G on March 24, 2003 at 11:43:51 from (24.236.190.20):
In Reply to: Re: H transmission seals posted by Tim K. on March 22, 2003 at 00:28:43:
Thanks for the all the info. I did manage to get the coupler off with out having to remove the clutch shaft. in fact i ended up using the clutch shaft as a puller to get the coupler off (something i read about in another post) I was thinking of pulling and replacing the throw out bearing since it does make a little noise when i push in the clutch. From what you describe it dosen't sound to be too bad of a job. When you say to put the new seals in flush with the retainers, do you mean the back side of the retainer or the lift all side of the retainer?
Post A Followup
: Re: Re: Re: H transmission seals
