706 Injector Pump Install
Posted by Brett M on March 22, 2003 at 13:17:38 from (12.13.119.82):
Greetings! At the risk of showing my complete ignorance, I need help installing my rebuilt injector pump on my 706. The pump came with a tag indicating it is to be installed at TDC on #1 cylinder. I removed the inspection plate, found TDC on the flywheel. I also removed the lifter cover (it was leaking anyway). I rotated the engine one revolution back around to TDC. During this revolution the intake valve (second lifter from the front?) went up and back down. I believe I am ready to install the pump. Any input from those more knowledgable would certainly be welcome.
Thanks to all in advance
Brett M
Post A Followup
: Re: 706 Injector Pump Install
