Re: 460 D Wide Front End Sits Higher??
Posted by mikeinmo on March 25, 2003 at 18:53:08 from (208.31.189.228):
In Reply to: 460 D Wide Front End Sits Higher?? posted by David on March 25, 2003 at 18:48:35:
What size tires does he have on the tractor? I had a 460 Farmall that I put a Schwartz wide front end under. I ran 9.5Lx15 on the front and 16.9x38 on the rear. The front end did not sit higher on it.
Post A Followup
: Re: Re: 460 D Wide Front End Sits Higher??
