Re: Some tactics on getting a motor unstuck?
Posted by Heath on March 25, 2003 at 19:02:59 from (208.29.50.254):
In Reply to: Some tactics on getting a motor unstuck? posted by Farmall Daddy on March 25, 2003 at 17:37:24:
I think Big John and the rest had some good advice. I have heard you can weld a grease zerk into a spark plug and install it into a cylinder with the valves closed and pump in grease with a grease gun to break it loose. Then remove that spark plug and turn over by hand to squirt the grease out before using starter or pulling or you will bend a con rod. Just an idea.
Post A Followup
: Re: Re: Some tactics on getting a motor unstuck?
