Re: 460 D Wide Front End Sits Higher??
Posted by Brent on March 26, 2003 at 10:57:08 from (129.186.243.110):
In Reply to: 460 D Wide Front End Sits Higher?? posted by David on March 25, 2003 at 18:48:35:
I have a '62 560G with the same look. It has the 38" tires on the back, and the front has 6.00 x 16". This was originally my uncle's tractor (got it new) and he had put a WF on to replace the narrow soon after his purchase. I just assumed the added front-end height was from some mounting bracket difference from NF to WF? Maybe it is the front tire size then?
Post A Followup
: Re: Re: 460 D Wide Front End Sits Higher??
