Re: 460 D Wide Front End Sits Higher??
Posted by Hugh MacKay on March 26, 2003 at 17:46:06 from (209.226.247.49):
In Reply to: 460 D Wide Front End Sits Higher?? posted by David on March 25, 2003 at 18:48:35:
My 560D had 7.50 x 16 on front and 16.9 x 38 on rear. It sat just a shade high on rear. You put 14.? x 38 rear ( I've forgotten . on 14) and 6.50 x 16 front and a 460 will sit just a shade high behind. Those rear tires will give you best pulling on farmland, it just nicely makes a tractor of both. Don't go with 15.5, it has no higher profile than a 13.6 tire. I once ran these two as duals together, same height. 15.5 inside and 13.6 outside. 14.? is actually a higher tire.
Post A Followup
: Re: Re: 460 D Wide Front End Sits Higher??
