Re: 300U Power Steering Problem
Posted by dick on March 27, 2003 at 08:38:20 from (65.59.18.249):
In Reply to: 300U Power Steering Problem posted by Bill on March 27, 2003 at 05:17:34:
Bill, the original power steering setup for the 300U required a special regulator, safety, and flow control valve which is different from the one used on the tractors which came without power steering. This valve is the one in the rear next to the hydraulic fluid reservoir with no control valve handle coming out of it.
You probably don't have it, but will need it in addition to the cover you're talking about to make the power steering work the way IH originally intended. Of course, a kludge is possible if necessary.
Take a look at the valve you've got and see if it's got plugged holes and such in the top, bottom, and rear. If so, that's the one used with power steering (valve body is part #364842R or #364844R); the one used with non-power-steering tractors was #360622R.
Send me an email if you've got more questions. I may be able to help with parts, also.
Post A Followup
: Re: Re: 300U Power Steering Problem
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
