Re: Super C leaking fluid at hydraulic pump.
Posted by jarrod on March 29, 2003 at 10:57:33 from (12.150.128.132):
In Reply to: Super C leaking fluid at hydraulic pump. posted by John on March 29, 2003 at 09:48:17:
The parts u will need are the 2 o-rings behind
the line block at the front, and the gasket at
the other end of the line at the resovoir. I
think there is a gasket at the pump u will need
and u will need to know the serial number, if i remember right to get the right one.
Post A Followup
: Re: Re: Super C leaking fluid at hydraulic pump.
