Re: Re: Super C leaking fluid at hydraulic pump.
Posted by CNKS on March 29, 2003 at 18:40:12 from (207.178.96.211):
In Reply to: Re: Super C leaking fluid at hydraulic pump. posted by jarrod on March 29, 2003 at 10:57:33:
The gaskets and O-rings for the lines are the same for all pumps, only some of the internal parts are different. Rear gasket (at reservoir) 350706R2, front gasket (at pump) 350708R1, o-rings (available anywhere) 350667R1.
Post A Followup
: Re: Re: Re: Super C leaking fluid at hydraulic pump.
