Re: Gearbox oil pressure warning question on IH 484
Posted by Bernard le mécano on March 29, 2003 at 19:27:04 from (142.169.50.101):
In Reply to: Gearbox oil pressure warning question on IH 484 posted by Ted Mount on March 29, 2003 at 13:48:44:
Hi Ted,the switch is for hasard flasher. The warning light is for lube pressure, the oil pressure circuit for the pto,return to the transmission by cooler and when pto is engaged, flow is higher then pto off. It's for warning light came on and off. A transfer pump, in the bottom of the transmission, allow oil for lube too. It sound like that is transfer pump bad.
Bernard le mécano Québec Canada
Post A Followup
: Re: Re: Gearbox oil pressure warning question on IH 484
