Re: Re: 504 electrical questions
Posted by Chad on March 31, 2003 at 13:38:04 from (206.230.0.251):
In Reply to: Re: 504 electrical questions posted by Bob M on March 31, 2003 at 12:00:01:
Bob,
Not to ask a dumb question, but is the extra wire that you are referring to, to be taped off, is it the white wire (thereby using the black wire from the wiring harness to connect straight to the coil)? For the previous coil, the end of the white wire is split, with one connection being made at the coil and the other connection made at the resistor. The black wire runs straight from the wiring harness to the other end of the resistor.
Based on your previous response, am I correct in assuming that both wires are at 12V and that while cranking, power is sent through the white wire to the coil (thereby bypassing the resistor and providing 12 volts to the coil)? Then once the engine starts, power is switched and supplied by the black wire (sent through the resistor, providing 6V to the coil)?
I'm just wondering which wire to tape off. Any help is greatly appreciated.
Thanks,
Chad
Post A Followup
: Re: Re: Re: 504 electrical questions
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
